My "Special" toy
EKSPCL
Post by EKSPCL »
Done 3 coats of primer filler 80, 120, 240 grit
Now for the white primer today.....
I'll sand this with 400 grit tomorrow.
Then another coat and 600 grit ready for painting on another weekend :!:
My 6yr old daughter said
Getting there 8)
EKSPCL wrote:Is the pinstriping paint always an enamel :?:
If so why can all of these cars be done when most are probably acrylic :?:
As far as I know yes, they use it as its slower drying and bites into the paint a bit depending on how they thin it.
basic.green
Post by basic.green »
not long now to you see some colour 8)
building the dream Rick
EKSPCL
Post by EKSPCL »
Blocked back and another coat ready for another block :shock:
And now I have bleeding fingers from 4 days on the sandpaper :evil:
Stygian
Post by Stygian »
EKSPCL wrote: And now I have bleeding fingers from 4 days on the sandpaper :evil:
At least you know you have worked hard on it. Getting there EKSPCL. Looks good :)
rosco
Post by rosco »
You've come a long way in just a short time - it's "paint season" again now.... just pick the best days (low humidity - moderate temp) - that's my philosophy......
If you've shot acrylic - I'd give it a bit of "air" to let it pull down before blocking back..... or you may have to re-do (block again in a week or so) it if solvents haven't all evaporated.... this depends a bit on how much "build" has been applied......
Pin-striping enamel..... - can't help with this - don't know anything about them..... but I'm leaning towards what Brett has stated - the enamel may have some solvent in it which "bonds or etches" into acrylic...... a "test" piece will probably save your finish paint.....
I'm pretty much convinced, normal enamel will not affect acrylic - haven't seen it yet..... but acrylic will certainly "bubble' or "blister" enamel......
For those six months - you did the right thing...... there is no point in trying to spray down here when humidity is high and temps are low..... often it's better to leave the old coat on and do other projects, rather than to strip and leave bare steel exposed in winter........
Good work, don't forget to "step back" and enjoy it every now and again...... the end result will come - don't forget to enjoy the journey to it......
EKSPCL
Post by EKSPCL »
Thanks Rosco.
I am going to let it "breath" before i lay down any color and also before I do the final primer block back.
rosco
Post by rosco »
You won't regret it - make sure it gets good air flow over it.... just leaving it in a closed up shed won't do as good as having doors and windows open on a warm, windy day...... I'd probably go against getting any hot sun on it though...... if you can avoid it...
You'll know it's done most of it's stuff when you can't "smell" the thinners when you take a "sniff" up against it...... they'll continue to come out for a long time - but for blocking back..... a week of good weather with plenty of "air" will do most of it..... two if you are anything like me.....
I like to leave top-coats for yonks before compounding - final top coats - not the ones you are going to block down "between" coats.....
I still haven't compounded that luggage compartment of mine yet..... it's only had eighteen months or so..... should be well on the way, by now......? Black's a bugger of a colour (no arguments about it being a "colour" please)..... it relies purely on reflection - and any imperfection can be seen easily in it.......
EKSPCL
Post by EKSPCL »
Thanks again Rosco :wink:
EKSPCL
Post by EKSPCL »
Picked up a pair of spats and a set of wheel trims this morning.......
8) 8) 8)
EKSPCL
Post by EKSPCL »
Hooray :D a little colour :!:
Inside bootlid and pillars Grecian White........
Dash Grecian White and Satellite Yellow........
MMM shiney off the gun 8) 8)
The body is now a rub-down off painting, so I'll get stuck into the doors, bonnet and guards with the primer and spray them with the body.
matches
Post by matches »
really coming along nicely, is it just my screen colours or does the yellow have a slight green tinge to it? looks 8) either way, not long now and you'll be able to let the tips of your fingers grow back :lol:
cheers, luke.
EKSPCL
Post by EKSPCL »
The color does look a bit different on the computer Matches.
It's more of a pastel yellow
V8EK4us
Post by V8EK4us »
Sweet as Wayne, sweet as!! 8) 8) 8) keep up the great work mate!
