Lowered FB
Lowered FB
I've been thinking about how low you can get an FB or EK, here's what I'm thinking if you go to low the tailshaft will hit the tunnel, so can you make the tunnel bigger as in height ways so the car can be realy dropped on its guts? As I have to replace the floor anyway I might give it a go, unless someone can give me a good reason not to do it! Waddya recon?
mallia10a
Post by mallia10a »
Your idea will get the car low allright however with the characteristic body roll of the FB/EK I feel you might get in trouble with the tyres fouling the guards particularly at the back. You can gain clearance in the rear guards by folding in the lip around the arch making sure you smooth them out to prevent them cutting into the tyre wall ( you probably know this anyway). I haven't seen or known anyone to have tried what you are about to embark on but I wish you luck. The old girl will look cool i'm sure.
Can't see a problem there at all Trev. Dropped spindles and stiffer lowered springs (or at least heavy duty as you don't want to bottom out to easily! I've seen it happen :shock: :? ) and reset rear and blocks, this way at least you can easily raise it to a legal height if need be :shock: :lol: :lol: ...
Tunnel mods shouldn't really be that much, keeping in mind how much it will move. Split it down the middle and raise it up! I'm hoping I don't have clearance issues once fully loaded.
Did anybody know the tunnel in a EK is offset toward the drivers side. Found this out when I had a 9 inch modified to suit and the tailshaft hit the floor on the passengers side :oops: Does any one know how to post pictures as im a bit of a computer novice?
EK283,
check out this sticky
http://www.fbekholden.com/forum/viewtopic.php?t=194
email me if you still can;t work it out.
Stewart
Post by mrs ratbox »
i've had some very low eks and what we did was as mentioned split the hump and raised, it one in particular had the front crossmember chanelled plus drop stubs and cut springs the bottom of the front guard behind the wheel was 3'' off the ground and if you had rear seat passengers the rear spring hangers would scrape on the ground over bumps
Hi ratbox I think it's time we saw some pic's of these cars they sound pretty wild 8)
there in the photo section under mick's FB's and EK's put up by torquefc (thanks)
