Grey motor mechanic wanted, Perth Area
benadamson
Post by benadamson »
Hi Guys
I recently bought an EK wagon after some 10 years of searching and dreaming. Im keen to join the local Perth FB/EK club and get involved.
Hopefully ill post up some pics soon
Ive had some less than satisfying experiences with mechanics recently and want someone who is able to take their time do things right. No major work needed, just an honest bloke who likes the old girls.
Anyone steer me in the right direction please?
Thanks
Ben
J
Post by J »
G'day mate, what is wrong with it?
some of us may be able to help.
Otherwise there is some place out in welshpool i think? Ask (Aust)Mod
fastjbav6
Post by fastjbav6 »
Hi Ben,
Where about in Perth are you located.
Regards Seb
Yellow Knight
benadamson
Hi guys
Im in Fremantle.
I had Langham Auto engineers, Radium Street Welshpool, play with the timing last week and so far, so good. I am simply hoping to find someone closer to home, however at the end of the day i dont mind going back out to Welshpool.
I would still like to have the carby looked at as there is a bit of a hesitation as i go to take off that is frustrating and means i ride the clutch more than id like to.
In addition to this i find the radiator fluid gets oily/fuely pretty quickly.
Also im not sure if the temp gauge works?
Other than that Tony at Olden Holden has been great. He is repairing my fuel tank next week.
Im still chasing:
a working headlight dimmer mechanism
Good re-chroming service?
Apolthesry/seat re-spring service?
Some info on seltbelt options (none at present), i would like to fit some, at least in the front
(AUST)Mod
Post by (AUST)Mod »
Go and see Tony at A classic Olden Hantke Pl off Radium Street Welshpool. Tell him Andrew with the Yellow FB sent ya :)
Mattso63
Post by Mattso63 »
Hi Ben,
Welcome :) I'm in Coolbellup and have a EK wagon I'm doing up so might be able to help with some things. Re. your carby, the first thing I'd check is your linkages to see if there's any loose play there. Otherwise the plunger might need replacing, and carby kits are realtively cheap from Coventries in Bibra Lake. But it could also be related to your timing and I know I had to advance my dizzy a fair bit to make it run smoother.
There's a wealth of information in this forum so take the time to search around, I'm sure there's some good advice in the Technical section.
Cheers.
blue ute
Post by blue ute »
benadamson wrote:Im still chasing:
K & D Chrome Metal Finishers
7/34 Davison St
Maddington
9493 4390
First Class Motor Upholstery
2/1792 Albany Highway
Kenwick
0407425376
Ben for anything 'non WA related' (parts wanted etc) try posting on the national forum rather than 'What's happening in W.A' - you'll to get more results that way. :) :) :)
feute
Post by feute »
G,day Ben
I can help with the seat upholstery and seat springs
let me know if you are still in need
contact me on pm or email
gary@wa.fefcholden.org.au
Gary
ben
Post by ben »
Ben try 'about time spares' on line for small bits like headlight switches etc
As for seat belts buy new ones from Auto One, Malz etc, they cost around the $90 mark per set. You will need some backing plates (unless you can make them yourself) which i know you can buy from 'go gear racing' in osborne park.
Welcome to the forum Ben , there is a place called Seatbelt Solutions in Colin Jamieson Drive in Welshpool, they can reweb or modify belts to your requirements.
(AUST)Mod
Post by (AUST)Mod »
Me old mate Blacky lives in the hills and is an honest mechanic of sorts :lol:
I would recommend him, although I think he has graduated from grey motors :lol:
