Steering column dash bracket - wanted/ wanted repaired
Richard
Post by Richard »
Hi forum
I noticed that my stock steering column dash bracket is cracked/ split. It appears to be manufactured of a metal alloy, and welded to the dash, not bolted. It is visible from the front when you're in the drivers seat. (Nb when I read the instructions on how to post a photo I'll put one up).
Has anyone had success in welding one of these if not, does anyone have a spare, solid one, kicking around.
If I don't repair it, the steering wheel will eventually just flop on my lap while I'm driving.
Kind regards - Richard
Re: Steering column dash bracket - wanted/ wanted repaired
Richard , it should be bolted to the dash , the bolts are accessed by removing the dash gauge cluster.
I am pretty sure I have a drawerful of them in the shed :thumbsup:
if it's the part i'm thinking of the same as blacky is thinking, i also have spares still will have to post it but just a little closer if you want it
Richard
Post by Richard »
Hi guys - that's great. It's almost midnight here atm as I check mail. Will come back when my brain wakes-up!
Kind regards - R
