Dynamat
Re: Dynamat
I put Dynamat in my '46 - dont think I would use it again , its expensive and the stuff I got from my trimmer mate did a better job noisewise.
The stuff he sells is about 12mm thick - I put it in my '64 Chev and it was the quietest car I have built
Went with the Dynamat because apparently its the best but I am not convinced.
Re: Dynamat
The Rodders Journal did a feature on Dynamat a couple of issues back. Very interesting reading. It seems they do different types and to cut heat and noise you'd need at least two layers possibly three.... all varying thickness.
Re: Dynamat
Doesn't Stinky sell a version of Dynamat for better value $ ?
Paging Dr Stinky, Dr Stinky, to the curteousy phone please
Re: Dynamat
In my experience, I though dynamat was the best after trying that ceramic paint from the USA, but in the ek, I ran out of dynamat and just used the normal stuff the upholsterers use ( like removalist's blanket ). I reckon it is just as good. I am bringing a bit more dynamat in from the USA but I am only using on the doors now. It's not much cheaper from USA but if you need a bit of it, it's worth it, and it's easier buying from them than chasing it up here. Also saw some on gum tree a few months back
Regards Ian
Regards Ian
Re: Dynamat
Rocket industries Eastern Creek, enough to do the FB ..$120
Re: Dynamat
I sell all types Dynamat, generic Dynamat styled gear (Roof Seal) and the traditional underlay.
Generally I can price all of them a lot less than most.
Re: Dynamat
Decided to give this one a go in the EK, will report back with the results
http://www.ebay.com.au/itm/40sq-f-Car-S ... 300wt_1153
- $_57.jpg (92.3 KiB) Viewed 1061 times
Re: Dynamat
I have a mate putting that in his HQ right now Brenno. Doesnt look to be too bad a kit.
