4 Speed Auto Advice Behind 202
bonnie
Post by bonnie »
Hi i am at my wits end hear, I would like to fit 4 speed auto into EK,( which allready has hydromatic box) will it fit in tunnel and any other advice most welcome cheers :shock:
Re: 4 Speed Auto Advice Behind 202
it should fit in the tunnel 99.99% sure, then you'll need the adapter stuff and and a fabricated crossmember and a modified tailshaft
Check out the Castlemaine rod shop web site, they have kits (as Mick said).
minifb
Post by minifb »
I only had trouble with it just touching the firewall And since i couldnt weld i ended up taking it out.. But am keen to do it again if i can get someone to weld for me..
FB/EKForum member 123
Gday Bonny
Are you talking a Turbo 700 conversion?
if so, see here - http://www.fbekholden.com/forum/viewtop ... 26&t=10988
FATBOY
Post by FATBOY »
just finished doing this conversion in my fc wagon.Just got to get it to the exhaust shop to get the exhaust pipe tweaked .Drives fine just got to work out what ratio diff is in the rear end(hr) ive got a 3.55lsd to install Where thinking it might have 3.08or 2.78 as its a bit sluggish of the mark.The car needs a good run
regards fatboy
(AUST)Mod
Post by (AUST)Mod »
FATBOY wrote:just finished doing this conversion in my fc wagon.Just got to get it to the exhaust shop to get the exhaust pipe tweaked .Drives fine just got to work out what ratio diff is in the rear end(hr) ive got a 3.55lsd to install Where thinking it might have 3.08or 2.78 as its a bit sluggish of the mark.The car needs a good run
regards fatboy
Pics and more info please :D
regards fatboy
Thommo wrote:Gday Bonny
FATBOY
Post by FATBOY »
Will take some pics when its at the exhaust shop tomorrow
regards fatboy
bonnie
Post by bonnie »
Thanks Harko , Those fact sheets,are valuable thanks heaps. :D
bonnie
Post by bonnie »
Fatboy, hope to see your pics soon cheers
