FB flash - top sections
V8EK4us
Post by V8EK4us »
I need the FB stainless trim for the top of both back doors and fins........pleeeeease.
Should be able to help out there Gaz - will check tomorrow.
V8EK4us
Post by V8EK4us »
Blacky wrote:Should be able to help out there Gaz - will check tomorrow.
:D :D :D :D :D :D :D :D :D :D
mlodge
Re: FB flash - top sections
Post by mlodge »
gaz
maybe able to help out also, i am in darwin and know of some gear sitting in a shed which you could check out
V8EK4us
Post by V8EK4us »
mlodge wrote:gaz
Thanks mlodge, which FB/EK are you running??? Next friday night is the Nostalgia cruise and we should have "pearl" there for it's first cruise (and last in Darwin :( :( ). Send me a PM if you want to come along. As for the FB trims, Blacky came to the rescue and they are all done and fitted......... but thanks for the offer, much appretiated 8) .
mlodge
Post by mlodge »
Gaz
still rebuilding have found a bit of rust on the front y or k frames trying to track down more info if they can still be purchased at all, so at the moment it is just a small hobby to fill in spare time. i would like to catch up with you and maybe learn a little more if you have a spare minute or two.
cheers
max
diamond offshore
berrimah
