FB flash - top sections
I need the FB stainless trim for the top of both back doors and fins........pleeeeease.
Re: FB flash - top sections
gaz
maybe able to help out also, i am in darwin and know of some gear sitting in a shed which you could check out
Thanks mlodge, which FB/EK are you running??? Next friday night is the Nostalgia cruise and we should have "pearl" there for it's first cruise (and last in Darwinmlodge wrote:gaz
Gaz
still rebuilding have found a bit of rust on the front y or k frames trying to track down more info if they can still be purchased at all, so at the moment it is just a small hobby to fill in spare time. i would like to catch up with you and maybe learn a little more if you have a spare minute or two.
cheers
max
diamond offshore
berrimah
cheers
max
diamond offshore
berrimah
