extractors.
fj_225
extractors.
in need of extractors for the 253 in the fb.rather try for type that doesnt go through the inner gaurds.any info greatly received
cheers shane.
fj_225
extractors.
thanks for that trev
i will have to see if any body has a second hand pair of the others then.trying to get the old girl ready 4 the nationals
fj_225
extractors.
hi trev. stock ones dont fit worst luck not enough room because of steering rod
cheers shane.
I was speaking to Mick ( ratbox ) a while back and I think ( hope I recall the conversation correct ) he said that he able to was use the standard 253/308 cast iron manifolds in one of his Ratbox V8 Conversions Pty Ltd projects in an EK ??.
Shane, are you able to lift the engine mounts a bit higher to enable them to allow clearance for the shaft?
Suppose you've probably already thought of that though..............
Just a thought................
fj_225
extractors.
hi fb mad. thats not a bad idea i shall have a look at that on saturday.
we made our own but this was on the EFI heads care of V8EK4US idea.
There is a hell ofa lotta work involved but they look the goods when finished.
http://www.fbekholden.com/forum/viewtop ... 3&start=60
fj_225
extractors.
hi scoob. is that 1and half or 2inch tubingcheers shane.
