59 Caddy Tailights - Indicators
NoMAD
Post by NoMAD »
I'm sure it's been done but my young age hasn't witnessed it....
anyone use 59 caddy Lights as Front Indicators...plan is to use these
i'm assuming it's as simple as drilling out the FB housing base to take it, and simply putting a similar type gasket in between, but just thought i would ask the hand of seasoned vet's as i haven't bought them yet!
NoMAD
thropzed
Post by thropzed »
NoMaD, Personally I don't like em. They are too long for the front. See if you can shave 1 inch or 2 off them to get the right proportions. I'd just bolt the whole housing to the indicator with a rubber gasket and run the wiring through the hole in the indicator fitting! Good luck
FB/EK Car Club of QLD.
I think they look pretty good :D
Harko
Post by Harko »
Love em but Id cut back the cylinder section and just leave the bullet 8)
I cut mine down on the '64 - cut 'em with a grinder then sanded the cut smooth with a piece of sandpaper on a sheet of timber - did the same to the base of the old lens and glued 'em together with Loctite 604. Been on there for 12 months and 9000 miles , havent fallen off yet..........
J
Post by J »
Nomad, pretty sure classic plastic have some cool ones adapted to fit the front indicators. If i remember correctly the bagged purple ek has them... if not, the same bloke but on his daily ek (check out his thread)
Post by Mick Jagger »
had these
kmawic
soup ladle grill bro
kmawic
