J's EK doin some foolay siek skidz bro (vid)
J
Post by J »
Ok well today I went in to with the intent to just paint up a few bits and bolt in together.
He is quite busy with 3 cars in the shop so I just did a few things and had to get some assistance from him every now and then.
Bolted on all the chrome, new fuel pump (i broke the other one :roll:
Then towards the end of the day we got the engine sitting in there!
Might have a bit of a problem with radiator clearance, might have to bolt it on the outside.
But yeh doing front engine mounts on saturday!
I could be wrong but it looks like the fan is on backwards?! :?
Standard fan will work just as well on the 161, don't think you'll gain any noticeable HP :lol: :lol: running that flex fan, plus it could end up hitting the radiator core....
Getting there though! 8)
Post by Mick Jagger »
that pushing ,161red,oh what an engine,no sarcasim here i got 60,000 hard revving klms out of one,4 boxes(2 opel)and the same number of diff centers ,Strong little fuccker it was
turn the fan around its pushing
ben
Post by ben »
Getting there J 8) Mate pretty sure the fan has to go the other way around. The edge of the blade that the blue centre piece attaches is the leading edge and the motor turns clockwise as viewed from the front. You will also need a shim block between the fan and pully or the blades will hit the fan belt. If you dont have the mounting/shim block your best running a stock fan for now
in days gone by we would do this shit,sometimes by ourselfs and no one would know,I rebuilt a motor once with the wrong size rings ,finished it about midnight ,gee it blew some smoke and then didnt go anymore.New Story
I paid $1000 ish back in the mid90s for a fully worked 6 (HP BLOCK)yella terra rockers ,starfire rods ,hp pump ,bathurst 6000 head,(allready had triple bolt ons rah de rah) freshend it up in the shed ,filled up the oil ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,the oil pick up was on the bench ,I could not beleive it.Im careful now
Mick Jagger wrote:,161red,oh what an engine,no sarcasim here i got 60,000 hard revving klms out of one,4 boxes(2 opel)and the same number of diff centers ,Strong little fuccker it was
Mine runs a 161, good little motor, also had an LC GTR with a 161 in it with the opel 4 speed...
J
Post by J »
hahahahahaha im an idiot :roll:
we even turned the engine to do up the torque converter!
whats this shim block? couldnt I just make up some kind of spacer?
if its all to hard it doesnt matter, got the fan for free :D
Post by mrs ratbox »
you probably won't have the room to space the fan out
ben
Post by ben »
Spacer J it needs to be about 20mm wide as you will see when you turn the fan around. Im talking from experiance as i tried fitting a flex fan a while back. Its a real tight fit.... i had mine on and running good at idle and down the street but when i gave it the right foot on the hwy the fan flexed into the radiator. It only just nicked it but was enought to f%^& it. I think i still have the spacer here which you are welcome to, but personaly i would stick with a stock fan, the small gain is not worth the headache :wink:
oldnek
Post by oldnek »
Ben , Was your a offset spaced fan blade type or even spaced fan blade.
FB MAD
Post by FB MAD »
I'm having a guess here but I reckon you'll be struggling to get that fan in there with enough clearance to miss the radiator unless somehow you can get the engine mounted as far back as possible without hitting the head and/or bellhousing on the firewall/trans tunnel.
And as others have said,fan is on backwards.
I'd just be useing the standard fan.Trouble free fitment and it will pull enough air for what you want unless of course you want a pretty looking fan to make it look tougherer :wink: :wink: :wink: .
ben
Post by ben »
Same as the one pictured John, although it was 5 blades and smaller in diameter. In saying that i think the one pictured here is also to big in diameter and will hit the top and bottom radiator hoses ?. The one i fitted from memory had about 10mm spacing between blade and fan belt and the same between blade and radiator. But at high rpms the pressure that flattens the blades must also flex the bades towards the radiator a little. I could of milled more of the spacer, but really felt it was all getting to little tolarance all round. I really only tried it for piece of mind with the condensor in front of the radiator and my lack of faith in aftermarket thermos. There are two thermos on the condensor and i noticed one not working, gave it a flick with the finger and of it went :roll:
J
Post by J »
Im gonna struggle to get a fan in there period..
gonna run a reversed thermo fan.
Also - engine mounts are now welded on after a lot of screwin around yesterday. Made a backing plate for the bellhousing as well.
On the road probably late next week
Standard fan should fit J, if I remember I'll try and get a pic of mine. It all came out of a HK and fits very snug....
