Dual Circuit Brakes.....
I am yet to go this trip - but will probably go to the n'th degree - only two things stop cars, brakes and something equally as big...............traffic lights do not STOP cars - keep an eye out everyone - it is becoming more regular to watch traffic pass across even though you face green..............
thinking of replacing my lines with stainless - probably won't make much difference to my use of the old bus, but perhaps for the next generation/s.......
Yes it is possible but you still may need a proportioning valve setup depending on how the final braking effect is.
I spoke with Terry at Hydroboost in Melbourne recently about this and he thought in my case (307 into EK) with HQ front calipers and HR rear that I would be better to use a VH44 booster on the front ( VH44 boosters have a bigger cylinder than VH40 boosters) and leave the rear unboosted.From memory some early Valiants and/or Fords had boosted front brakes only??
He felt with the VH44 boosted front HQ brakes and unboosted HR rear that I should get near the desired 60/40 braking proportion.
If not, then a proportioning valve is needed.You can buy aftermarket adjustable proportioning valve setups which would be a better.
FB1960
thanks for the replies guys
can someone post photos of the master cylinder mounted so I can see the clearances
trev did you reinforce the mount at all because by our measurements the drivers side bolt will only be going through the firewall and not into the pedal box
Marty
Going nowhere, getting there fast
- ekdave1962
hi there i removed my pedal box and welded an extra bit on so there was something to bolt to ..
holes for hq master
Templete i made so i drill out the right hole got hq master .. not 2 holes fit the old ek pattern so it could be bolted to the wall to drill out the main hole, the other 2 holes are the location holes for securing the HQ master
modified pedal box so Hq master has a secure mounting
hope this helps a little
holes for hq master
