Door jamb/dome light switches
Looking for a pair of FB/EK door switches. The ones I am thinking of are a steel cylinder, with a light spring and black plastic button. They normally live on the front door jambs, and activate the dome light.
I decided to put switches into the rear doors of my EK wagon project... thought I had plenty of spare switches, but can't find any in the spare parts department. Holes are drilled, wiring run, but no switchies.
Happy to pay reasonable costs and postage.
Re: Door jamb/dome light switches
harv, these can be had new from rares, but i think about $40 each... if you can't find any in reasonable knick...
i can have a look through the parts bin next weekend if you haven't found any buy then, but they are likely to be in rough shape
Nathan
Nathan
Foundation Member
Foundation Member
Small hole or the larger one? Ive got some NOS rares ones that i never used (Small hole)
Cheers Theo Z............
FB/EK Car Club of QLD.
Common fit EK to HZ at least for the smaller ones. Never paid for one as they are generally prolific in the wrecking yards I have been known to frequent. A bit of a rub with emery paper and splice in to loom.
I remember my mate had fitted pivoting arms with self tappers to his HR wagon. These could be turned to cover the door switch so the lights didn't come on when the door was open.
I will have some in a few weeks when I'm back out home mate let me know. I should have a few about
I can see these ones at Rares:
http://www.rarespares.net.au/rarespares ... uct=SW2030
I'm guessing these are the "big hole" ones - when you look at the door jamb, you see the black button, but also the steel surround.
The ones I am after must be the "small hole" ones. When they are installed, all you can see is the black button (and a tiny rim of steel surround). If it helps, they fit into a hole of about 9mm diameter.
If anyone has a pair, it would be much appreciated.
Yes the FB ones. Not nearly as common.
You should be able to get a pair of the EK ones off a HQ-J-X-Z at the local wreckers for a few bills.
There might be a pair in here somewhere
Later type has a flat head?
I should have some here but can't find a matching pair. Can't even find the ones out of my 215 sedan, retro fitted back in the 80s.
You probably want to match the front ones Harv.
Looks like the local telephone exchange in India! Let me put you on hold Sir and I will connect you..............Errol62 wrote:There might be a pair in here somewhere
Looms from EK special, standard and van and FB standard. All the wire is brittle and oxidised.
These are the beasties I'm after - round head, almost no "lip" showing when installed.Errol62 wrote:
Do They have to be oem holden ones Harv
FB-Special
Big block 161
Holley sniper EFI.
Ek auto column shift.
Lj diff and reverse lights.
WA FB~EK Car Club Member.
Big block 161
Holley sniper EFI.
Probably common with local Vals etc of the era. Trico or someone like that?
theres bugger all Valliants left eirther , any reason you don't like the ones kingswood country are selling on ebay they are the later square looking button but they are new not 40 years old.
