control arm bushes
munro
control arm bushes
Post by munro »
where do i get hr control arm bushes from?
whats the signs that the pins where the bushes screw too are worn?
sorry to sound ignorant but up till now my experences with rebuilding front ends hadn't dated before LC.
cheers tom
Malcolm
Control arm bushes
Post by Malcolm »
Tom,
I got a full rebuild kit on EBAY for a HR front end for about $340. Worked out a lot cheaper than buying the parts separately. The same person also sells the parts seperately for a reasonable price also. Sorry I can't think of his name but he's always on ebay selling front end parts under the HD/HR heading.
The big nuts that screw onto the pins that go through the cross member should be firm. If there sloppy than thats a pretty good sign that there stuffed.
Malcolm W.
munro
Post by munro »
i bought a kit off ebay with everything exept the bushes (cheap)
the bushes were tight and there was no slop in the control arms but i figgured that while the front end was out (and that it's my wifes car) i should recon it.
i'll check out ebay and see if i can find that guy.
cheers for the advice
tom
ben
Post by ben »
Tom
Rare spares would probably have the bushes in stock
Apparently Supercheap have them too - this was discussed on here a couple of years ago and someone said Supercheap - the price was pretty good too from memory.
munro
Post by munro »
ended up getting some $148
expensive little f#@*ers :roll:
cheers for your input tom
