well i drilled all the welds out on the battery box and removed it so i could get the SU's in place properly for a test fit and measure to cutout the firewall
i ended up not doing what i did in the photoshoped version above. it would have been way more room then neccesary so i only moved the firewall 1 inch.
ive still got a little more metal work to do on the top ive used metal i cutout of the gearbox tunnel and also the part i cutout of the firewall to do it as i didnt have any steel handy.. so its kinda a bit of patchwork which will take a bit of cleaning up but oh well.. i think its ok for my first every custom shaped metal
not as pretty as you guys do but ill try make it beautiful with the grinder and stuff before i ever get to the undercoat.
it also means i no longer have to modify my extractors yay plenty of room for those now.
i also fitted the master cylinder and clutch cylinder and pedal box.. i figure i may as well build the car now get it running and then pull it apart for paint.
any suggestiosn on what radiator to run?
