Chopped Ute
Harko
Re: Chopped Ute
Post by Harko »
Yep definitely 48 chev coupe ute
original
chopped
Just good to know where its from thats all !
(AUST)Mod
Re: Chopped Ute
Post by (AUST)Mod »
Harko,
Will this ute be road registered?
Harko
Re: Chopped Ute
Post by Harko »
Yes mate ,by my understanding of the mpv rules as of right now all the mods I have done and have planned will pass.
Didnt think the window was quite right so I took some shape out of it - happy now :)
(AUST)Mod
Re: Chopped Ute
Post by (AUST)Mod »
Awesome.
What sort of background do you have that you are so skilled in metalwork?
Harko
Re: Chopped Ute
Post by Harko »
I worked in Franklins once ,I was a roof plumber ,tour guide ,scaffolder ,builders hand.
It was a necesity to learn how to weld to gain what I wanted ay :wink: 8)
kiid61
Re: Chopped Ute
Post by kiid61 »
"tour guide"
That's right up there with airport hostess. I hear Quantas are always searching for extra welders to fix their planes, but don't like spending the extra cash on extra staff. You could get a job as a hostess/maintenance worker. So long as you don’t mind working out doors at heights and in speed welding wings back on planes?
Re: Chopped Ute
Post by Mick Jagger »
:) franklins thats where you learnt it
kmawic
Harko
Re: Chopped Ute
Post by Harko »
So I decided to use some of the skills learned in Franklins back in tha day ,We used to slice open boxes like this :shock:
But in all honesty it started out needing more tyre under the guards ,It works out the guards are a factory 17mm narrower to the rear.
The rail at the top of the tray is 30mm narrower to the rear , hmmm if I push the quarter out it will square it up ,give me more tyre room ,and fatten up the rear profile . done :D
Harko
Re: Chopped Ute
Post by Harko »
kiid61 wrote: You could get a job as a hostess/maintenance worker. So long as you don’t mind working out doors at heights and in speed welding wings back on planes?
It fits the criteria Kid , wouldnt mind this type of work :)
http://www.youtube.com/watch?v=D3BlZi5Z ... re=related
Re: Chopped Ute
Mate,
Thats awesome but check this out ! Its the industry im in at the moment.
http://www.youtube.com/watch?v=LIjC7DjoVe8
BAT 62
Re: Chopped Ute
Post by BAT 62 »
THAT REAR WINDOW LOOKS TOUGH HARKO .GLAD TO SEE THAT TRAILER LOAD OF RUSTY TREASURES MADE IT HOME SAFELY. KEEP THE PICS COMING, REGARDS STEVE
kiid61
Re: Chopped Ute
Post by kiid61 »
Very Cool Greg..
This is messed up!!!.. http://www.youtube.com/watch?v=gPvCuc1_ ... re=related Did you see this one Harko? I use to mess around on 150ft boom lifts at my old work and that was bad enough. 1000+ft with no harness climbing up a pole :shock:
Re: Chopped Ute
I wouldn't do that for $1,000,000, it was scary enough to watch :shock: .
Harko
Re: Chopped Ute
Post by Harko »
They do that for community service :)
Thanks Bat for your hospitality mate ,was good to meet you .
Harko
Re: Chopped Ute
Post by Harko »
The car went backwards to go forwards today hardiddyharhar ,I just wish they were built right in the first place !
Ive finished widening the driver side of the body , stripped the tubs from it and the floor in the tray :cry:
Im planning to pump the quarters a touch and run the new inner guards out to the quarters and tack/glue them there rather than having the inner wall .
apart from the offset I was worried about the stock rims before now it should easily go 9s maybe 10s.
Ill have a look at swapping the chassis rails side to side later and see if it will gain some more but still be um factory.
The rails bow outwards stock :shock: and Id reckon bowing inwards would be much better :wink:
