swage lines, Help needed
oldnek
Re: swage lines, Help needed
Post by oldnek »
wot179 wrote:I made a hammerform for my tubs.Then you can make them any shape you like.
I used cold rolled bright mild steel to tap them up cos it moves easier than zinc anneal,and tigs up nicer.(still hard work cos I used 1.6)
Hope these might help.
Thats a damn shame to paint that over, I would just clear it and let it look all natural.
Nice Job 8)
I haven't used a hammer form as yet, did you still have to shrink the roll curves, or is that finished straight with dead blow.
oldnek
Post by oldnek »
Another way you could try and swage, is to use a section of cattle grid and a piece of hardwood dowel. I have made swages using steel gutter grid (which is smaller in size-re:length) You know the ones you used to get your pushbike wheels stuck in :lol: and broom handle the same way with good results.
Somewhere I came across a link where a couple of blokes in Thailand where building a Kombi ute, just using primitive hand tools, fabricating all repair sections by hand.
They were making the rear floorpan using a chisel and wood block, very time consuming but worked.
wot179
Post by wot179 »
Pretty much straight off the hammerform.I had it clamped down pretty well with loads of clamps and another lump of ply.
It also had a 20mm return folded down on the bottom edge cos I need that for a hidden fixing into the timber floor,but it had the added advantage of stopping the metal pulling
forward off the hammerform as I pulled the edge over with the dead blow.
Ive been a sheety my whole adult life,but this is my first attempt at making or using a hammerform.
Just bring it around gently and try not to bring too much over at once.
I have lots more pics if you want me to start a thread.
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
oldnek
Post by oldnek »
wot179 wrote: I have lots more pics if you want me to start a thread.
You should do and then the Mods can post it as a Sticky, this is what people want to see. The more we post up the better it is for all.
wot179 wrote:I have lots more pics if you want me to start a thread.
Bring it on 8) 8) 8)
Ed
Post by Ed »
+1 :D
more pics would be great, I love this kind of stuff.
FE/FC Holden Car Club of NSW
Yes please!
oldnek wrote: Somewhere I came across a link where a couple of blokes in Thailand where building a Kombi ute, just using primitive hand tools, fabricating all repair sections by hand.
I have seen this also, it was amazing.
wot179
Post by wot179 »
Jake: SCMODS?
W.S.C.C.A.
St Marys chapter.
Ed
Post by Ed »
Just a follow up on an old thread...
I ended up buying a bead roller and then bracing it up etc to stop the arm from walking.
besides the silly crank handle, which I want to change next, it's easy to use. teh quality is OK for hobby type use (which is me).
now a question...
I rolled some beads into the floor of a Datsun ute I'm building. I thought.. should hte beads face up or down? I ended up facing them down as I figured over time they would get dented from people getting in and out.
Ed
Sounds to me like you made the right choice Ed 8)
