For a while now my dash lights have failed to work in my EK, however the high beam light works and the indicators flashers do to....as it seems they are earthed the same as the dash lights then it must be a faulty light switch at the knob...?
Any help appreciated....
Cheers MAIKI
EK -Dash lights no workie, but indicator 'indicators' do....
The Kardinals, Melbourne.
Re: EK -Dash lights no workie, but indicator 'indicators' do
indicators are earthed separate to the dash lights, grab a test lamp and start probing
Ahh, cool thanks, ill get the multimeter out!
Cheers M
Cheers M
Corrosion on the copper spring ring thingy?
Cheers Theo Z.....................
FB/EK Car Club of QLD.
In the light switch.....did I read somewhere these things dim...? or was that later models...?
Cheers. MAIKI
Cheers. MAIKI
Yeah, The dimmer coil might have corrosion and stops powering up. Just turn it a few times to get the right spot, or pull the switch out and give it a rub with some wet n dry? Worth a try?
Cheers Theo Z........................
Yep Maiki they do have a dimmer, give the headlight switch a twirl. Mine has a spot where they dont work.
As others have said give it a clean up as it could just be that.
