NoMAD's Kustom FB Sedan
hey Harko!
not sure i haven't looked into anything yet. I was thinking one of these
http://www.tciconverters.com/Products/GM/gm_2004r.asp
Universal Lock-up Kit
Installation of this kit makes retrofits into non-ECM 700R4 or 2004R vehicles a snap. System allows automatic operation of the TCC in 4th gear under stable engine operation, and disengages the clutch when accelerating or down shifting. Also provided in the kit is a manual override option. Constructed from OEM connectors and oil resistant wire, we install this kit in all our complete 700R4 & 2004R StreetFighter® Transmissions.
Description Part No.
Lock-up Wiring Kit 376600
Replacement 2-wire TCC Solenoid for 2004R/700R4 376601
Harko what did you do since you've done it???
NoMAD
NoMAD
progress....
Got round to finishing the real gearbox crossmember today....
From the Rear
From the passenger side
Fun stuff - the 16" Lokar Shifter (I love it!!!!)
And initial tunnel work!
NoMAD
From the Rear
NoMAD
its a Lokar shifter from the States...very popular with the hot rodders which is where i pull a fair bit of inspiration from...like what my paint & interior & wheels will be!
www.lokar.com
the shifters come in all different sizes up to 32" mines a 16"!
The boots & rings you buy seperatly....but i think you can also use aftermarket ones!
http://www.lokar.com/interior_pages/indicatorsboots.htm
I also have the control module & an in dash LED indicator!
there not cheap i warn you now!
NoMAD
www.lokar.com
NoMAD
nomad.... or yes mad!!!!
like trev said
NOICE...
looooove the the length of the shifter...love it, the higher the better... i was thincking what a long column shifter would look like... as mine's still up there...
keep the pics comimg
matty martin
NOICE...
matty martin
go the wagons....
Woo back to the front page!!!!
Yes i know its been a while since i updated...but its been a while since any major works has begun due to partying in Canada for almost a month - hence where most my funds went and working to much aswell!
But work has begun in the Boot...plan is to hunt down an XB tank in the next week or 2 and finish replacing the section that has been cut out below, finish off some minor works and then spray the boot inside!
Bottom Side
Top Side
should be doing lots of work this year, so we try and keep the pictures coming!
NoMAD
Bottom Side
Top Side
NoMAD
as the boot work generally continues without to much to update...was quite hot working in the shed today...so kept in minor just working on some accessories at the moment...
front end, engine, gearbox, diff in for a while so we can roll it around and then started the fun....
Well its in for a moment so i thought a few of you may enjoy it...i know i do...
Hopefully get the boot finished in the new month or 2
NoMAD
NoMAD
So little bit on the boot today....the Boot finally had its Wheet-Bix, since i couldn't get a tank.
As 1 strenghtener was completely missing and the other completely rusted away, we made these up not original but alot stronger!
Template
Folded Up
Both Tacked In
Next load of Boot Work should be the tank, filler/Fuel Flap and the Battery Box/Tray Area.
NoMAD
Template
Folded Up
Both Tacked In
NoMAD
