NoMAD's Kustom FB Sedan
NoMAD
hey Harko!
Post by NoMAD »
not sure i haven't looked into anything yet. I was thinking one of these
http://www.tciconverters.com/Products/GM/gm_2004r.asp
Universal Lock-up Kit
Installation of this kit makes retrofits into non-ECM 700R4 or 2004R vehicles a snap. System allows automatic operation of the TCC in 4th gear under stable engine operation, and disengages the clutch when accelerating or down shifting. Also provided in the kit is a manual override option. Constructed from OEM connectors and oil resistant wire, we install this kit in all our complete 700R4 & 2004R StreetFighter® Transmissions.
Description Part No.
Lock-up Wiring Kit 376600
Replacement 2-wire TCC Solenoid for 2004R/700R4 376601
Harko what did you do since you've done it???
NoMAD
Post by mrs ratbox »
rocket industries has something like that
NoMAD
progress....
Post by NoMAD »
Got round to finishing the real gearbox crossmember today....
From the Rear
From the passenger side
Fun stuff - the 16" Lokar Shifter (I love it!!!!)
And initial tunnel work!
NoMAD
noice :wink:
Looking good there NoMad :D ,
Trev 8) .
Mr Nomad,
Looking good!
Where did you get the shifter from?
Does it come with a rubber boot? Or does it need a consol?
NoMAD
Post by NoMAD »
its a Lokar shifter from the States...very popular with the hot rodders which is where i pull a fair bit of inspiration from...like what my paint & interior & wheels will be!
www.lokar.com
the shifters come in all different sizes up to 32" mines a 16"!
The boots & rings you buy seperatly....but i think you can also use aftermarket ones!
http://www.lokar.com/interior_pages/indicatorsboots.htm
I also have the control module & an in dash LED indicator!
there not cheap i warn you now!
NoMAD
greg EK283 if you want one of these shifts, i have mates that work at rocket industries they are distributors for lokar products i'll see what price i can get it for, if you want
Thanks Nomad & Ratbox,
I also know a guy who is employed by Rocket.
I just need to decide what length shifter I need.
Ratbox if I need assistance I will let you know,
Thanks Greg
Those tunnels would have to be one of the best things CRS have ever made. Sure do save time and standard auto carpet fits! Looking real good there Nomad...
mattymartin
nomad.... or yes mad!!!!
Post by mattymartin »
like trev said
NOICE...
looooove the the length of the shifter...love it, the higher the better... i was thincking what a long column shifter would look like... as mine's still up there...
keep the pics comimg
matty martin
go the wagons....
NoMAD
Post by NoMAD »
Woo back to the front page!!!! :lol:
Yes i know its been a while since i updated...but its been a while since any major works has begun due to partying in Canada for almost a month - hence where most my funds went and working to much aswell!
But work has begun in the Boot...plan is to hunt down an XB tank in the next week or 2 and finish replacing the section that has been cut out below, finish off some minor works and then spray the boot inside!
Bottom Side
Top Side
should be doing lots of work this year, so we try and keep the pictures coming!
NoMAD
rosco
boot
Post by rosco »
Thanks NoMad,
love to watch progress........... looking good..........
Working in my boot at present, but in top coat stage.....
NoMAD
Post by NoMAD »
as the boot work generally continues without to much to update...was quite hot working in the shed today...so kept in minor just working on some accessories at the moment...
front end, engine, gearbox, diff in for a while so we can roll it around and then started the fun....
Well its in for a moment so i thought a few of you may enjoy it...i know i do...
Hopefully get the boot finished in the new month or 2
NoMAD
NoMAD
Post by NoMAD »
So little bit on the boot today....the Boot finally had its Wheet-Bix, since i couldn't get a tank.
As 1 strenghtener was completely missing and the other completely rusted away, we made these up not original but alot stronger!
Template
Folded Up
Both Tacked In
Next load of Boot Work should be the tank, filler/Fuel Flap and the Battery Box/Tray Area.
NoMAD
