Page 1 of 2
Exchange clutch supplier - Brisbane
Posted: Wed Nov 25, 2009 7:27 pm
by strogger
Hi Team,
Just a brief note on a supplier in Brisbane who can do an exchange clutch kit for Grey Motor powered FB/EK's.
1 Business day turn-a-round and I was quoted $210.00
(Cheaper than the Ebay dude and no frieght.)
Action Mechanical Services - 490 Nudgee Rd, Hendra
#(07) 3268 6888
All they need is your pressure plate in rebuildable condition.. (worn but not totally u/s.)..
I am getting mine done shortly, so will advise on out come.
Posted: Wed Nov 25, 2009 10:18 pm
by Cal
Strogger, aren't you better off going for a red motor clutch?
Much cheaper, and longer lasting
Posted: Thu Nov 26, 2009 8:04 pm
by strogger
Cal,
I've missed something here?
Does they Red motor clutch kit fit the Grey??
If they do, then hell yeah, I most certainly would be better off..
Let me know please (And which of the Red family to use. 138, 149, etc.)
Thanks..A.
Posted: Thu Dec 10, 2009 11:42 pm
by fb cruisin
I have an EH clutch in mine the EH/HD clutch was smaller than a HR clutch and fits a grey
Posted: Fri Dec 11, 2009 8:11 am
by Cal
Sorry Strogger, I forgot all about this thread
When I had my clutch replaced some months ago (by Dr. Terry), he put in a red motor clutch. As far as I know if bolts straight on
Posted: Fri Dec 11, 2009 8:42 am
by FB MAD
Cal wrote:Sorry Strogger, I forgot all about this thread
Yep, the EH clutch as Rob ( fb cruisin ) said, is the one to use.
Posted: Fri Dec 11, 2009 12:20 pm
by Stygian
What exactly do you need to install the EH clutch into the crash grey 'box? Just the disc or the whole assembly (disc, pressure plate, etc)?
Andrew
Posted: Fri Dec 11, 2009 12:51 pm
by Cal
I know with mine it was the complete clutch kit, as the old pressure plate and clucth plate were rooted
Posted: Fri Dec 11, 2009 4:17 pm
by Stygian
Cal wrote:I know with mine it was the complete clutch kit, as the old pressure plate and clutch plate were rooted
Thanks Peter. Just had a look on EvilPay- EH kits are $145 from the Ebay store "Sunbury Brakes Online", plus $18.95 Registered Parcel Post. This is cheaper than the $220 exchange for the grey motor kit by the other Ebay store "Straightline Performance".
Also cheaper than the $210 strogger was quoted.
Andrew
Posted: Fri Dec 11, 2009 7:01 pm
by Cal
Yeah, they are much cheaper than the Grey motor clutches.
I'm not sure if there's any minor mods that need doing tp fit the red clutch to a grey..........I'm positive mine was a straight install
Posted: Sat Dec 12, 2009 1:16 pm
by fb cruisin
They are a straight swap, no mods needed.
I would have the flywheel machined, because the grey motor clutch is 8 inches and an early red clutch is 8.5 inches so the mount face is larger.
Posted: Sun Dec 13, 2009 9:20 am
by Stygian
fb cruisin wrote:They are a straight swap, no mods needed.
Thanks FB cruisin.
Yet again, the forum has taught me something new. I will definitely use a red motor clutch in my project now... the larger size should work well with a sports grey...
Posted: Sat Dec 19, 2009 9:30 pm
by strogger
Thank you all..
Saved me and by the looks a few other a few $$$ and a bit of rooting around..
Posted: Mon Jan 04, 2010 8:39 pm
by woodsy
Excellent! We are going to replace the clutch in the EK because its bloody horrible! Saw the $220 Exchange clutch on ebay for the Grey's but if the EH Red motor clutch bolts straight up its a big saving.. Thanks fellas!!
Re: Exchange clutch supplier - Brisbane
Posted: Tue Oct 26, 2010 3:51 pm
by skin_dog
Hey all,
i also am going to be replacing my clutch soon so will definitely be taking this EH clutch option, but as i'm a bit of a mechanical novice some of the things mentioned here aren't quite making sense.
Could someone explain how and why the flywheel needs to be machined? If the grey clutch is 8 inch and the red is 8.5 that sounds to me like the grey flywheel is already too small, but like i said i'm a novice so i'm probably missing something.
Thanks,
Ryan
