Exchange clutch supplier - Brisbane
Hi Team,
Just a brief note on a supplier in Brisbane who can do an exchange clutch kit for Grey Motor powered FB/EK's.
1 Business day turn-a-round and I was quoted $210.00
(Cheaper than the Ebay dude and no frieght.)
Action Mechanical Services - 490 Nudgee Rd, Hendra
#(07) 3268 6888
All they need is your pressure plate in rebuildable condition.. (worn but not totally u/s.)..
I am getting mine done shortly, so will advise on out come.
#(07) 3268 6888
Anthony..
FB/EK Car Club of QLD
www.qldfbekholden.com
- State: NSW
Yep, the EH clutch as Rob ( fb cruisin ) said, is the one to use.Cal wrote:Sorry Strogger, I forgot all about this thread
When I had my clutch replaced some months ago (by Dr. Terry), he put in a red motor clutch. As far as I know if bolts straight on
What exactly do you need to install the EH clutch into the crash grey 'box? Just the disc or the whole assembly (disc, pressure plate, etc)?FB MAD wrote:Yep, the EH clutch as Rob ( fb cruisin ) said, is the one to use.Cal wrote: When I had my clutch replaced some months ago (by Dr. Terry), he put in a red motor clutch. As far as I know if bolts straight on
Andrew
Thanks Peter. Just had a look on EvilPay- EH kits are $145 from the Ebay store "Sunbury Brakes Online", plus $18.95 Registered Parcel Post. This is cheaper than the $220 exchange for the grey motor kit by the other Ebay store "Straightline Performance".Cal wrote:I know with mine it was the complete clutch kit, as the old pressure plate and clutch plate were rooted
Also cheaper than the $210 strogger was quoted.
Andrew
- State: NSW
Thanks FB cruisin. Yet again, the forum has taught me something new. I will definitely use a red motor clutch in my project now... the larger size should work well with a sports grey...fb cruisin wrote:They are a straight swap, no mods needed.
I would have the flywheel machined, because the grey motor clutch is 8 inches and an early red clutch is 8.5 inches so the mount face is larger.
Re: Exchange clutch supplier - Brisbane
Hey all,
i also am going to be replacing my clutch soon so will definitely be taking this EH clutch option, but as i'm a bit of a mechanical novice some of the things mentioned here aren't quite making sense.
Could someone explain how and why the flywheel needs to be machined? If the grey clutch is 8 inch and the red is 8.5 that sounds to me like the grey flywheel is already too small, but like i said i'm a novice so i'm probably missing something.
Thanks,
Ryan
Thanks,
Ryan
