Bench seat
fbman63
Bench seat
Post by fbman63 »
Hi all,
I am after a front bench seat for the FB Panelvan
Brisbane area. :D cheers
thropzed
Post by thropzed »
You after a stock bench or are you willing to put a later model bench in. I had a '98 Rodeo bucket bench in my EK Van. Was great. Folds forward to access the rear cargo, Comfort of a modern seat construction,Fit with very little mods. and can be trimmed to look stock!
Cheers Theo Z................
FB/EK Car Club of QLD.
ek ute
bench seat
Post by ek ute »
Theo
do you have photo of Rodeo seat installed?
I have floor shift & seat is cutaway to fit.
I interested in alternatives as seat isn't complete & needs trimming etc.
patrick
thropzed
Post by thropzed »
There you go!
Cheers Theo Z......................
arty64
Post by arty64 »
Question Theo,how do you get on with the gear change,did you have 2 bend the shifter :?:
thropzed
Post by thropzed »
No! It fit nice and snug. The last pic shows the gear stick in first and second it sat up against the seat. Only problem was the seat couldn't slide forward much at all. Lucky it flipped forward. It bolted straight into the stock rear bolt holes and the fronts had to bend the bracket out flat and drill a new hole, but it is inside the original seat support bracket under the body, so no engineering cert.
Cheers Theo Z.........................
arty64
Post by arty64 »
8) Thanks 4 the info Theo,may have 2 look at doing this when i get my ute back from the painter.This way i wont wreck my bench seat
ek ute
bench seat
Post by ek ute »
thanks for the photos!
looks a good alternative
patrick
matches
Post by matches »
theo, you wouldn't know what the height of the backrest is would you?
thanks, luke.
