Where do I connect the heater pipes and the temp sender? I can see two spots, one on the head and one on the water pump. But I will need three holes won't I? (btw its a grey motor). Can I put in a 't' or will there not be sufficient flow with the heater pipes off for the temp sender to work?
any help greatly appreciated.
strike me down, and I will become more powerful than you can possibly imagine.
Looks like the head on your car is off an FE or FC Greg. These heads only had one outlet for a temp switch. FE/FC's had one outlet in the water pump and another outlet from the thermostat housing. These two outlets went to the heater. FB/Ek heads had two outlets and one in the water pump and didn't have the outlet in the thermo housing. Best thing is to get an FE/ FC thermo housing and run this outlet to the heater.
Hope this makes sense.
later grey heads came with 2 points on the head one for the heater one for the temp sensor I dont believe using a T would be sufficent as as you said with the heater off you wont have flow sorry but im too pised to offer a solution
