Before I get to far into the conversion can someone answer the following questions for me please.
1. What outrigger do I need to fit to a HR disc brake front end for the 307 Chev?
2. What model torana steering rack will suit?
3. What diff should I use?? Just a normal commodore diff of 9 inch &*#@??
As always thanks for the help
Rodney
307 into EK
1. FE to EH outrigger.
2.LX,LH,UC for front mount rack and pinion steering. Ratbox has also done an LC,LJ Torana front mount one I believe??
Can use commodore for rear mount rack.VB to VH commondoor I believe??
3. Hmmmmmm............ so many choices to pick from??
Gday rod,
Alot involved in converting to a V8. You need to consider firstly what sort of power you want from the V8. The more power, the more modifications and the more it will cost.
I used a CRS chev V8 HR front end in mine. You then need to consider the braking set-up you will use. He also sells front mounted torana racks. I found this easier as the V8 mounts were already in place and the bracketry existed for the front mount rack.
Rear mount rack from a commodore will require alot of modifications to the sump.
As for the diff I wouldnt mess around and just go straight to a 9inch. 28spline will suffice for a low powered V8, 31 spline for big horse power. Note if you go for a 31 spline billet axle, your wheel caps probably wont fit over them
