Page 1 of 2
auto trans hump
Posted: Thu Aug 20, 2009 7:47 pm
by vintageholden
any one have an auto hump from ek/fb please
i want to fit an auto box
will be selling my 138 and 3 speed crash box soon
going 3.3 auto
Posted: Thu Aug 20, 2009 7:59 pm
by FB MAD
I think the ones available from castlemaine rod shop are a copy of the EK auto trans tunnel if that helps... unless of course you do actually want a genuine hump.
Posted: Thu Aug 20, 2009 8:11 pm
by vintageholden
how much are they and postage to perth???
thanks
Posted: Thu Aug 20, 2009 8:21 pm
by FB MAD
Sorry, have no idea, you'll have to ring them.
Posted: Thu Aug 20, 2009 8:42 pm
by fb cruzn
i got one few years ago from crs, $90 but think there up to $120ish now.
Posted: Thu Aug 20, 2009 8:46 pm
by fb cruzn
FLOORPANFC FLOOR TUNNEL SECTION TO SUIT LARGER TRANS IN FE-EK $120
http://www.rodshop.com.au/holden/fe-ek.htm
Posted: Thu Aug 20, 2009 8:52 pm
by Devilrod
This is well worth the money. I know of 3 people who have now used this tunnel. It fits perfectly and allows you to run standard auto carpet!!!! Plus saves alot of time spent stuffing around to make one then have custom made carpet to cover it.....
Posted: Thu Aug 20, 2009 9:01 pm
by vintageholden
thanks guys
Posted: Thu Aug 20, 2009 11:53 pm
I just rolled a piece of sheet around an oxy bottle and folded both sides to make my own. Piece a piss.
Posted: Fri Aug 21, 2009 3:49 am
by Trev
Blacky wrote:I just rolled a piece of sheet around an oxy bottle and folded both sides to make my own. Piece a piss.
I made my own as-well, cost SFA ($10 tops)
, as Blacky said just get a flat bit of sheet steel and bend it over something round, it is not a complex shape with bumps and swage lines in it! Trev
Posted: Fri Aug 21, 2009 10:37 am
by vintageholden
i was going to do that
didnt want to sound tight
Posted: Fri Aug 21, 2009 3:01 pm
by FB MAD
It will make you feel better to know that you did it yourself AND saved money.That's how the old hot rodders did it, not being a tight arse in my eyes.
Posted: Fri Aug 21, 2009 4:01 pm
by Devilrod
FB MAD wrote:It will make you feel better to know that you did it yourself AND saved money.That's how the old hot rodders did it, not being a tight arse in my eyes.
Not always a case of being a tight arse. Time can also be said to equal to money...
Be careful making your own tunnel that its dimensions are the same as an auto hump, otherwise your cost cutting will bite you when it comes to the carpet costs....
Posted: Fri Aug 21, 2009 4:11 pm
by FB MAD
I can give you the approx dimensions of the EK Auto hump if you want to make your own.
The original hump has an annoying brace about 2 inches high that runs over the top about 1/3rd ( 1/4 ?? ) way back from the rear and is rivetted to the floor/hump/under floor brace.
I don't think there is a real need for this brace personally but if you feel there should be one there you could make one that does the same and is a lot less intrusive.
Posted: Fri Aug 21, 2009 4:27 pm
by mrs ratbox
it's the cross member that's normally under the floor in most cars
i've cut plenty out and also seen LOTS of cars that don't have it
