colapsible column which one?
Posted: Sun Aug 02, 2009 7:50 pm
by fatfbwagon
hi guys im running a 202 with hr front end and rear mount commodore rack and pinion. just wondering which is a good colapsible column to use and what knuckles do i use to connect column to rack. saw a few at holden day but couldnt make out what they were off. cheers wayne
Posted: Sun Aug 02, 2009 8:58 pm
by matchew
well i reckon for starteres anything hq or after is no good as they have the key in the column, and i no my bro used hg in his fj
Posted: Mon Aug 03, 2009 5:08 am
by yeprat1
im about to use a uc steering column cut down and welded to the original column and using al the knuckles off a uc as well thats how the mechanic doing mine does them and then he makes his own rod .ohh but mine is front mount dont know if it matters.
Posted: Wed Aug 12, 2009 7:47 am
by fatfbwagon
ok thanks i will talk to engineer first thanks wayne
Posted: Wed Aug 12, 2009 8:48 am
I used the top half of an EK column and the bottom half of a VB/K Commodonor column on my rear mounted rack. Pretty easy to graft them together , needed to machine a circlip groove in it - that was the only bit I couldnt do in the shed.
