colapsible column which one?
fatfbwagon
Post by fatfbwagon »
hi guys im running a 202 with hr front end and rear mount commodore rack and pinion. just wondering which is a good colapsible column to use and what knuckles do i use to connect column to rack. saw a few at holden day but couldnt make out what they were off. cheers wayne
love is sweet, love is golden, love should be made in an fb holden
matchew
Post by matchew »
well i reckon for starteres anything hq or after is no good as they have the key in the column, and i no my bro used hg in his fj :?:
always a good day for cars
yeprat1
Post by yeprat1 »
im about to use a uc steering column cut down and welded to the original column and using al the knuckles off a uc as well thats how the mechanic doing mine does them and then he makes his own rod .ohh but mine is front mount dont know if it matters.
fatfbwagon
ok thanks i will talk to engineer first thanks wayne
I used the top half of an EK column and the bottom half of a VB/K Commodonor column on my rear mounted rack. Pretty easy to graft them together , needed to machine a circlip groove in it - that was the only bit I couldnt do in the shed.
