Page 1 of 2
Bad timing - gear + Twilight on Twilight
Posted: Mon Jul 20, 2009 6:12 pm
by Aussie Bob
Bad timing gear. I guess there is never a good time. Is there ever any warning? Car was running great.
What do you do, replace Fiber with a Steel timing gear?
Are they too noisy?
Does the gear get quieter after running for a while?
Two in one month :( This time it's the Twilight Turquoise FB. 7ks out from Singleton yesterday afternoon.
Q. What do you do when you are stuck on the side of the road for three and a half hours? ....
A. Get the Camera out :)
Twilight on twilight ....
Posted: Mon Jul 20, 2009 7:46 pm
by fb cruisin
Cool pics Steve 8)
Sunny Tim is there any particular brand gear you like, I've seen a few on evilbay and wasn't sure of the quality?
Cheers Rob
Posted: Mon Jul 20, 2009 8:32 pm
by Trev
The ones on ebay are from SA as-well, I have one on my motor, not yet run :roll: , Trev 8) .
Posted: Mon Jul 20, 2009 9:25 pm
by V8EK4us
Just goes to show Steve........ bad is not all bad.....there has been good come from it, awesome pics.....how can one man have sooooo much talent! (and so many nice cars!) :wink:
steel gear
Posted: Tue Jul 28, 2009 6:02 pm
by Lucy Blue
I have put steel gears in every car I have owned after the experince of doing two timing gears in 6 months in my first car then trusting to luck on my second and having it let go on the way to Canberra in 1995 Ah memories.
yes they are a little whiney and I only change the cam gear not the crank gear. but I never have had a problem with them.
and yes you can change them without taking the camgear out of the car!
Posted: Wed Jul 29, 2009 10:46 am
by CHO576
seems to be a popular subject at the moment Steve ...
http://www.fbekholden.com/forum/viewtopic.php?t=8060
I'm trying to make the same decision for myself right now - but with all the bad news about Fibre gears cropping up, I'm now leaning towards a Steel gear.
Any ideas best place to get them (Steel) in Sydney? ...
Jamie
Posted: Thu Jul 30, 2009 12:57 pm
by Aussie Bob
SunnyTim wrote:Steve. I did 3 gears in 1 year in 95, and have been running steel in all of my cars ever since. No timing gears in that time.......
They only seem to be noisy if you change the crankshaft gear with the one that comes with the set :shock:
I've have done 40,000 miles with just the top gear fitted, hasn't broken yet and is quiet.
On the FB, both gears were changed in the steel set by a mechanic. The engine sounds very noisy, almost like the noise is coming from the middle of the engine?
Bearing? or Timing gear? I haven't heard the engine myself as it is still down south.
Can anyone shed some light?
Steve
Posted: Fri Jul 31, 2009 12:19 pm
by CHO576
Steve Jackson wrote:The engine sounds very noisy, almost like the noise is coming from the middle of the engine
the plot thickens ...
mate - be interested to hear what the outcome of this is ...
Posted: Wed Sep 02, 2009 8:38 pm
by bebop67
My car did a timing gear at the week-end coming back from ballarat club run. Definetley wont use a fibre gear, ive ordered a steel one from reidy.
Does anyone know what type of puller i can use and where can i purchase one, the one i have is a cheapy from super cheap and wont work on the crank gear.
Posted: Wed Sep 02, 2009 8:46 pm
by Aussie Bob
Beb, don't change the Crank gear, only the Timing gear.
Steve
Posted: Thu Sep 03, 2009 7:36 am
by parisian62
Steve,
have you got the Twilight back? did you get to the bottom of the nosiy engine...
Stewart
Posted: Thu Sep 03, 2009 8:24 am
by Aussie Bob
Hi Stewart, The Twilight is back on the road. It was the Seagull with the noise after the timing gear was replaced. Not sure what the noise is, so we are going to pull the engine out and take a quick look. While we have the engine apart, we will ad new rings and bearings. It's all part of the fun :D
Posted: Fri Sep 11, 2009 8:13 pm
by Aussie Bob
Your on, what are you doing tomorrow?
Or don't you want to drive down an EK Hydra?
Posted: Fri Sep 11, 2009 8:37 pm
by Aussie Bob
OK lets do it. Your on the pay roll :) :) :)
Re: Bad timing - gear + Twilight on Twilight
Posted: Fri Oct 31, 2014 11:20 am
by kel3629
Any results on what the engine noise was after the timing gear replacement.
I seem to have the same problem
Thanks
Kel
