Moderators: reidy , Blacky
Harko
Posts: 2387 Joined: Fri Apr 07, 2006 9:36 pm
Post
by Harko » Fri May 22, 2009 7:29 pm
Hi all , Im after a roof or a good left half of a sedan roof , Sydney to Batemans bay prefered
fatfbwagon
Posts: 26 Joined: Tue Apr 14, 2009 8:12 am
Post
by fatfbwagon » Sat May 23, 2009 4:05 pm
i will have a look at the shell ive got here and let you know. im on central coast but. cheers wayne
love is sweet, love is golden, love should be made in an fb holden
Harko
Post
by Harko » Sat May 23, 2009 4:47 pm
Thanks wayne , sounds good .
fatfbwagon
Post
by fatfbwagon » Sat May 23, 2009 5:01 pm
hi i just had a look . depending on how much roof you need depends on how good it is for you. it has a couple of fist size dents in it but not too bad to fix. the front pillars are ok on the upright section but the bottom horizontal parts are rusted. the centre pillars are good and solid. and the rear pillars are ok on the inside. the drip rails have rusted off on the outside but they still seem pretty solid i guess. the centre section of at the top of the rear window is rusted out .the channel inside the car above the rear windscreen is rusted out too. but seems to be mostly on the right side of the car. im gonna take some pics so if you like send me your email address and ill send them to you thanks wayne
Harko
Post
by Harko » Sat May 23, 2009 5:44 pm
Wow , probably need a clean one ... Sounds like the good section on that is the only area I dont need ..
Thanks for the reply though , much apreciated
Harko
Post
by Harko » Wed May 27, 2009 6:09 pm
Just to add , I dont mind cutting the roof off myself ofcourse
minifb
Posts: 2416 Joined: Thu May 26, 2005 10:05 pm
Post
by minifb » Thu May 28, 2009 4:26 pm
I can get one here....Its in between syd and the bay VIA a little detour.....
FB/EKForum member 123
Woofto Car Club Member No4
Harko
Post
by Harko » Thu May 28, 2009 6:06 pm
Sounds good , Ill see if I can blow up another corolla on pick up
Harko
Post
by Harko » Sat May 30, 2009 1:29 pm
Are there any others around that someone may know of ?
Harko
Post
by Harko » Tue Jun 09, 2009 7:40 pm
anyone ? anything !
southcoastkustom
Posts: 537 Joined: Tue Nov 28, 2006 11:20 pm
Post
by southcoastkustom » Wed Jun 10, 2009 10:21 pm
One good one in Adelaide if ya want it Mark. You cut it and anything else you want off the shell urs for nics!
not too shiny thankyou.
