Diff ratio
Stuart Bowyer
Diff ratio
Post by Stuart Bowyer »
Hi all , what do people think is the best diff ratio is behind a 202 with Aussie 4 speed ? :)
cheers
Stuart
Aussie Bob
Post by Aussie Bob »
336 :D
robbyr
Post by robbyr »
3.08 , if you can find one
EKWagon
Post by EKWagon »
that REALLY depends on tyre ratio and size, from there you can work out how you drive the car and what diff ratio will work best for you
2.78 slow off the mark but low revs on highway through to 3.89 launch great off the mark and rev out at 50mph?
EKWagon
Love my 3.08 with 195/75/14's, red and trimatic, Trev 8) .
I've got 3.36 with 185/75/14 and its not bad but I plan on fitting a t700 behind a 186.
retro-richard
Post by retro-richard »
3.08 ive found to be good for city and country driving
Sammy
Post by Sammy »
i agree 3.08 is the best all rounder .....
having said that i too have a T700 behind a 202 and i have a 3.45 diff in it and it revs at about 2200rpm at 100kms whereas when i had the 5 speed with a 3.08 it used to rev at 2500rpm at 100kms ....
Regards,
Sammy.
http://www.oldholdens.com
slimboy66
my set up
Post by slimboy66 »
i have a 179 with a 3 speed with 14 's 185-75 any suggestions for that set up. i think it has 3.55 now and it revs alot
FB MAD
Post by FB MAD »
3.36 or 3.08 would be best could try 2.78 with a 179 but I don't think you'd be happy with it's pickup and wide gearbox ratios that a 3 speed box has.
Post by mrs ratbox »
if most of the driving will be around city i'de say 3.08 (this way still ok on open road) maybe 3.36 if lots of highway 2.78
but lots of if's but's and maybe's, like engine condition and mods if any tyre size as mentioned and ratios in the gearbox
gordon
Post by gordon »
I have a 3.55 am going to put in the new EK to reduce the revs a bit on the highway and correct the speedo readings...
Oldn67
Stuart Bowyer
good stuff Gordon , i had that on my list for her too !
gordon
Post by gordon »
Strange thing is my EH has 3.55 diff so I sort of know what its going to be like !
Someone on here had 3.08 with Grey motor Hydramatic , it would go back to 2nd gear on hills
Oldn67
stucross
Re: Diff ratio
Post by stucross »
Hi guys, useful info in the comments. I'm wanting to put a 3.08 behind my 202 and trimatic in an EK sedan. Now sorry for my ignorance but what's the best way to go about doing this?
Can you get 3.08 centres that go into existing otriginal EK diff housing or should I look at getting a drum to drum 3.08 out of a HR - which I've heard bolt straight in to the EK? or is this info incorrect?
Any help or clarity would be ver much appreciated.
Stu :?
