snowcrest white standard ek wagon_cruzin
righto.. plenty of questions coming... first one being.. i recently read a post on here regarding process for rebuild... where to start etc.. also had a heap of tips and tricks.. does anyone know the post i'm on about ?
Hi and welcome to restoration heaven.I am into a complete rebuild down to the last nut and bolt and the most important piece you should have before you start are about 200 clip lock bags and two permanent markers.trust me you will use them.oh yeah and plenty of pictures.
cheers
Tony
cheers
Tony
Stand and listen to knowledge turn your back on stupidity.......
Welcoe to the forum Mud', will be good to watch this evolve.
I use 3 diffent sized bags. Packed them in Left guard bolts, grille bolts, dash, glovebox etc etc..... now that we have done our first prefit and reassembly I am sooooo glad I did that
Good luck with the build mate.
I second that Tony!!t950cat wrote:Hi and welcome to restoration heaven.I am into a complete rebuild down to the last nut and bolt and the most important piece you should have before you start are about 200 clip lock bags and two permanent markers.trust me you will use them.oh yeah and plenty of pictures.
cheers
Tony
- ekdave1962
where to start ..
Well it depends on your goal really ..
ratbox would say its nearly completed ..
i see u have the surf board ready so a quick cut an polish a set of rack and off to the beach you ,,
Hmm a fellow Geelong member .. any chance the car was a triple J purchase ?
D
D
- ekdave1962
A soda blaster here where I live showed me recently some work he had done.
Soda blasting is brilliant for safe paint removal but struggles somewhat when it comes to the rusty areas.
He then uses a heavier blasting medium on the rusted areas to bring the rust out that the soda blast couldn't remove.
He said that after soda blasting the car doesn't have to be quickly primed to prevent rust starting on the bare metal as the fine film of soda left on the body acts as a temporary rust preventative via its chemical makeup.
and loads of BEER!!!V8EK4us wrote:Welcoe to the forum Mud', will be good to watch this evolve.
cheers
Tony
I use 3 diffent sized bags. Packed them in Left guard bolts, grille bolts, dash, glovebox etc etc..... now that we have done our first prefit and reassembly I am sooooo glad I did that.
aidan...
i'll get there....
- State: NSW
- Contact:
welcome aboard mudgroup. Looking forward to the rebuild of that one.
