Apparently swearing at your clutch return spring (from the dash to top of pedal lever) doesn't make it go back on, nor does the other dozen tricks I have tried, all of which also included swearing, not to mention a sore back from lying on the floor of my wagon plus approximately 10 or so skinned knuckles which also provoked some more swearing.
Does anyone have any tricks out there to get these springs strecthed open and over the end of the pedal?
My next point of call is to weld a wire to it, drill or find a hole in the firewall to thread it through, then winch the wire from my work bench till the spring stretches open enough to hook over the top of the pedal.... Then swear at it some more when it snaps or wrecks another part of my wagon and still doesn't go on....
EK clutch pedal spring help
old low 'n slow is the only way to go (cars that is)
I was thinking it was a pain in the ass to get that spring off when I did it
, never did I think about putting it back on
Swearing at it is where I would have started
, I am interested in how to do this also, sorry I can't help Trev
, Trev
- State: NSW
Got it back in.... I wasn't in the mood for pulling my restored steering wheel off and taking out my gauge cluster again (although the way rosco did it sounds like it would work fine) so I hammered half a dozen big flat bladed screw drivers into the spring which opened it up a bit, hooked the dash end up first, then used some vice grips clamped on the long straight part of the spring to stretch it the final few mms over the end of the pedal and into the groove. Then pull out all the screw drivers of course and all is done!
I can see why people don't bother putting them back on though, I don't think I can feel much difference in pedal resistance or return pressure, but hey, is done now.
Cheers for the input
