lowering questions
lowering questions
Just after some more info about lowering (2inch) , hopefully it hasn't been covered before.
Why are dropped stub axles better/prefered over lowered springs?
It is best to get and decide on the wheels before lowering isn't it?
How do you tell if the current leaf springs are no good, can you measure the deflection or similar?
Is there a disadvantage of blocks compared to getting leafs reset?
Thanks a lot
Thanks a lot
Lowered stub axles are preferred as they still allow for legal lowering of the car and still maintain the original suspension travel in full.Lowered springs ,whilst still legal (depending on the amount of lowering ) decrease the amount of original suspension travel on bump and are frowned upon in general by the rego authorities because the rego authorities like to frown a lot!!
Lower the car to where you want it first and then see if the wheels you want will fit and doesn't foul suspension components or front guard during full lock steering and full suspension movement.
Lowering blocks for rear springs are cheaper and easier to do than reset springs if you want it that way.Reset springs are also another avenue or a combination of reset springs and lowering blocks can also be used.
To check if your rear springs are sagged the general way to do it is the measure the distance between the rear bump rubber and the diff housing whilst the car is at normal loading and on a level floor and compare that to the factory specs.
Most cars will have sagged a bit in ride height over the years compared to the factory specs, some more than others.
and if useing drop stubbs this does cause more issues re:wheel tyre combo
there is other issues with the drop stubbs, because yor car is lower but still has full suspension travel in some situations this causes front cross member and or steering components to bottom out on the road and tyre fouling on guard issues, i'm telling you this from experiance
i'm not saying don't use them if i ever stumble across some for the right price i'de use them again
does anybody have 1 drop stubb as i have 1
Thats was the problem I had with my UC Torana with CRS dropped stubs a few years ago.
The crossmember would hit the road before the bottom wishbone hit the bump rubbers.
Solved the problem by extending the bump rubbers up 1 inch ( they are bolt on rubbers in UC Torana ) via a spacer block and stopped the crossmember hitting the road.
- ekdave1962
