Moderators: reidy , Blacky
FATBOY
Posts: 506 Joined: Wed Jul 06, 2005 7:50 pm
Post
by FATBOY » Tue Jan 20, 2009 4:22 pm
My lock broke today how do i go about fixing it
regards fatboy
DNA
Posts: 363 Joined: Mon Apr 21, 2008 12:03 pm
Post
by DNA » Tue Jan 20, 2009 4:34 pm
there should be a pin the the arm.
push it out and the lil arm should fall off.
FATBOY
Post
by FATBOY » Tue Jan 20, 2009 6:34 pm
mine broke the shaft that comes off the window as well
regards fat
sdc
Posts: 27 Joined: Wed Dec 26, 2007 10:37 pm
Post
by sdc » Tue Jan 20, 2009 8:05 pm
atlest you cant lock your keys in the ute with it like that
steve
FATBOY
Post
by FATBOY » Tue Jan 20, 2009 8:52 pm
Is there a epoxy i could use to re-instate the pin ie glue it together
regards fatboy
FATBOY
Post
by FATBOY » Thu Jan 22, 2009 8:43 pm
just finished fixing the lock .I drilled out the two dowels from underneath on a spare one that i had .Then i drilled the two on the car need a special offset drill (local engineering shop let me do it at there premises).Priced it off cleaned the spare one up got som metal glue of the shop glue and clamped into place will find out how it goes in the morning
Regards fatboy
V8EK4us
Posts: 1541 Joined: Sat Feb 09, 2008 12:12 am
Post
by V8EK4us » Thu Jan 22, 2009 9:48 pm
Hi Fatboy,
There is a product called "Liquid metal" sold by Snap-on, it works good when preped correctly but it could be cheaper and easier to find another lock
thropzed
Posts: 1160 Joined: Sat Jun 04, 2005 10:14 am
Post
by thropzed » Fri Jan 23, 2009 12:55 pm
Fatboy,
You know that if your repair doesn't work, you'll have to replace the whole quarter glass frame!!!
Cheers Theo Z...................
FB/EK Car Club of QLD.
