changing from linkages to cable
chrome_ek_girl
Post by chrome_ek_girl »
Hi all. I have used HEMIS idea and gone the L300 cable to use for my van. I cant find the link again for it. BUT......
I would really appreciate a hand
I have drilled holes in floor....end of cable now fitted onto my existing and original EK accelerator pedal.
Cable now goes through firewall where choke should.
I dont have anything to hold cable onto, so bought a "universal" clamp from outlaws. Have used 2 small bits of rubber hose and 2 washers either side to hold and clamp the cable into the clamp. Next thing is.....fitting it up exactly to my carb (350 Holley. I will take pics today and try to upload them, so you can see exactly what it is im doing..but if anyone would like to give me a hand, i would be sooo appreciative.
cheers
Flic
mmm....chrome....
ipg
Post by ipg »
gday flic,
i think youre after the following thread:
http://www.fbekholden.com/forum/viewtop ... ator+cable
agreed it was a fair way down the page when i searched for 'accelerator cable'
chrome_ek_girl
thanks
cheers for that........those pics and detail were so much help...
now...if i can just manage to stop the headache that is "fitment at carby" :(
anyone fancy a visit to my shed :?
mmm....chrome....
ipg
Post by ipg »
im sure if you let ppl know where you are, youll get a couple of locals to help out.
the main thing is getting the spring tension right
if you have a few spares to play with youll be right
chrome_ek_girl
HELP
Findon area..
Findon......
Findon............... :D
mmm....chrome....
stinky
Post by stinky »
Just let me know what time during next week is OK and I can have look, might not be able to help but at least I can look at it :lol:
I'm at Woodville Flic.
Pm sent :wink:
chrome_ek_girl
hmmm
ok.....
have set it all up.... (might have to message thommo yet) :P
seems i have not even got half pedal. Underneath my car, the accelerator pedal pivot doesnt seem to go very far back at all. When i first started doing it, i had to scrape away years worth of rust n crap from it. I still have a good inch for the lever/pivot to move back, but it doesnt seem to want to.
Anyone got any ideas???
mmm....chrome....
ipg
Post by ipg »
is it that the pedal isnt returning to its original position?
if so then the return spring tension isnt high enough; try a higher rated spring.
chrome_ek_girl
not the pedal return
No...inside the car...the pedal is fine......
underneath..at the accelerator pedal pivot thingo...(at the underbody...that little lever doesnt go all the way back in the small hole thats there....
is it supposed to???
mmm....chrome....
chrome_ek_girl
spoke to HEMI this morning
Well after speaking with HEMI (Mark) this morning, it might just be my actual accelerator pedal thats not giving me even half throttle...so anyway, here is the rusty (yes ive cleaned it up even) pedal lever under base of car. NOTE THE LEVER AT BASE ONLY GOES TO THE RIGHT HALF WAY..SHOULD IT GO FURTHER??
here is the cable and how its fitted underneath car
and NOW..here is how i fitted my cable using washers either side and some rubber hose clamped (bracket is a universal one i got from outlaws)
and the rest of my set up....below....(pardon the bad photography but its bluddy hot in the shed tonight....although nice n cool in the pit)
mmm....chrome....
FB MAD
Post by FB MAD »
Just by looking at the photo and not actually having an original pedal assembly in my hand to go by, I'd say some of your problem is that there isn't enough cable pull from the pedal actuating lever ( where the cable end meets the pedal).
If you cut, extend, and reweld that lever you will get more pedal lever travel and consequent further cable travel accordingly.
At a guess, I'd probably extend it by about an inch or so and see if that helps.
Not sure from the photo but it looks like you are running a holley ??
and if so, most of them have about 2 inch throttle travel at the carby.As it is I'd guess you would only be getting about 1/2 of that at present.
Might help, might not help, but see what happens.
MINT62
Post by MINT62 »
FB MAD wrote:If you cut, extend, and reweld that lever you will get more pedal lever travel and consequent further cable travel accordingly.
gday chrome ek girl
i did exactly this to get full throttle on my setup :wink:
INVEST IN PRECIOUS METAL
chrome_ek_girl
accelerator pedal bolts very rounded
hmm..so...
has anyone else taken out their accelerator pedal...and found that upon doing so....the bolts are so rounded off and old and rusty???
hmm...tackle this how??
have sprayed and sprayed...might just keep on spraying WD40 on em till they drop out... (i could hope)
Any ideas anyone? As im going to weld on another inch to it, hopefully get more leverage.
mmm....chrome....
Can you leave it in, make some sort of shield to keep the heat from the floor and do the job where it is? Trev 8) .
