SPRING SADDLE FOR DIFF SWAP
FCOV6
Post by FCOV6 »
Can someone tell what the width of the saddle needs to be, want to get some steel to make them and without having the car in the same suburb i cant just go out and measure ? Will get some RHS probably 100x100mm ?and split it using each half as a saddle.
thanks,
Nick.
FB MAD
Post by FB MAD »
If it's the diff saddle measurements your after I've just measured one from a grey diff assembly that I have out of a car.
It's 2 11/16th inch wide ( 68 mm ) x 4 1/2 inch long ( 104 mm ) with the centre bolt location hole diameter of 11/16th inch ( 23.5 mm ).
The original diff saddle is pressed metal and has an outside radius.The flat section bolt up face is 2 5/16th inch wide ( 59mm ) with same length measurements as above ie:- 104 mm etc.
FCOV6
Post by FCOV6 »
FB MAD wrote:If it's the diff saddle measurements your after I've just measured one from a grey diff assembly that I have out of a car.
Thanks mate, much appreciated, do you think 75mm RHS would be ok - i'm not sure what the spacing is for the U bolts in the shock plate are.
yeprat1
Post by yeprat1 »
fcov6 i have a set of original saddles if u need them im running hr diff.cheers troy
FB MAD
Post by FB MAD »
The inside spacing between the u bolts would be a few mm wider than the width of the saddle as the u bolts slip alongside the saddle when the diff/spring assembly is bolted together.
I've got an original FB/EK spring saddle in the shed so will go up and measure the saddle bolt hole specs and let you know later on tonight.
FCOV6
Post by FCOV6 »
yeprat1 wrote:fcov6 i have a set of original saddles if u need them im running hr diff.cheers troy
Thanks but i still have my old ones hanging on the wall to use if need be, i have a HR diff in the car now but that is making way for a VB salisbury with VN discs untill i finish shortening the VN diff.
Harko
Post by Harko »
I bought a pair of CRS for about $30 brand new perfect fit !
FCOV6
Post by FCOV6 »
Harko wrote:I bought a pair of CRS for about $30 brand new perfect fit !
Yeah i have seen them, i need them tomorrow though.
