measurements
matches
measurements
Post by matches »
hi, i'm just after the measurement between the clutch and brake master cylinders in an ek if someone knows real quick.
thanks.
L&K
Post by mrs ratbox »
how come ? i'll measure some but won't be back till about lunch time
matches
Post by matches »
just looking at options for dual circuit brake master cylinders for running commodore brakes with builtin booster if i can find one.
L&K
from centre to centre of cylinder holes in firewall 125mm, between from inside edge to inside edge of master cylinders 90mm, between inside edge to inside edge of tin resovoiurs 65mm, these are all give or take a couple of mill
matches
Post by matches »
thanks ratbox, that helps.
L&K
