my problem is that the spring bottoms out against the hanger theres no clearance between the spring and hanger at all,, so when you hit a bump it sort of has no where to go and stops the shackel being able to osalate,,
so i measured the spring and there 3cm longer than a standard sedan spring that i compared it to,,, so ive either gotta change springs or move the hanger back or maybe heat and bend hanger back to get clearance
i dont know what the springs are out of as it has a volvo diff ,, but they look like a holden spring ,, so im thinking to grind the huck rivets off and move the hangers back and drill right through chassis and fit bolts right through,,,, just wonderd if this is somthing that anyone has seen and which is the best fix ,,,,obviosly the heat and bend option would be easy,,
any ideas,,,, its not the original ute spring ,,as its only 4 leafs with no load spring
