EK Auto Column to Trimatic?
After some technical advice and help, we are currently fixing up an EK Sedan. We have a disc f/end a red motor and want to put a trimatic in it.
I want to know if this can be hooked up to an ek auto column and if so does anyone have one for sale?
hulaEK
Post by hulaEK »
Certainly can be hooked up. Running a trimatic on my column shift auto, hooked to the origianl grey.
Bolts on easy! :lol:
Thanks Hula,
All I have to do is find one now :roll:
Dr Terry
Post by Dr Terry »
Hi Devilrod.
Yes, you can make an EK column work.
The bits you need are the inhibitor switch & shift gate off an HD/HR Powerglide. The inhibitor switch is so you can start it in park & neutral & have reverse lights on in reverse. The shift gate bolts to the column tube, just above the steering box & gives you the position for the P/R/N/D/L gears in the correct order, which is totally different to the EK Hydra-Matic.
The linkage to the box will need to be tailor made out of a combination of EK & Trimatic bits. Use HQ-HZ stuff, they're plentiful.
Dr Terry.
Thanks Dr Terry, will start scrounging the pick a parts..
Getting close to firing her up. 8)
