Differences in FB EK brake drums?
Posted: Thu Jan 31, 2008 2:08 pm
by hz308prem
Hi all,
I have a pair of sedan rear drums at home, a guy wants to get them for the front of his EK panelvan, are these going to fit or do rears only fit rears and front drums only fit the front? Do comercials and sedans have different drums?
Thanks in advance
Peter
brake drums/shoes
Posted: Thu Jan 31, 2008 2:59 pm
by rosco
Hi Peter,
I can't recall ever swapping front for rears.............
just had a look at the good book - it states the same size both in diameter and width for drums and shoes - it does not give separate specifications.....
Armed with that, I am guessing they are interchangeable........ others may have better info.....
Posted: Fri Feb 01, 2008 9:43 pm
by ekv8ute
Hi HZ,
As far as I know the only difference front to rear is that the wheel cylinders are a different size, I believe the drums are the same size.
Regards Mark
Posted: Sat Feb 02, 2008 2:00 pm
by troy_fb
Ive swapped mine in the past, front to back while trying to get a better braking acton with no problems.
I'd be interested to know about the difference between those with the ribbed cooling fins and the solid ones though? Which were standard on FB/EK? Are the ribbed ones any better at staying cooler?
