Rear seat belts for wagons
Posted: Sat Jan 05, 2008 8:58 pm
by Trev
Just been installing seat belt mounting points in the Fb wagon, just wondering if anyone has put inertia real belts in the rear?
If so where did you mount them, on the pillar or behind the seat some where?
Any pic's would be good, Trev 8).
Posted: Sun Jan 06, 2008 12:08 am
by ben
Trev i found the only easy way for inertia belts in the wagon was on a bar behind seat. (there is a picture from the rear in 'one more wagon' pics) There is not a lot of options because of the angle that they work. I did have a look at mounting commodore wagon units, but it would take a bit of cut and paste, which may be worth the trouble if you don't want a bar.
Because of the way the pillars curve forward from the seat tops, its hard to get the right angles for piller mounts. Hopefully someone has a better answer.
Posted: Mon Jan 07, 2008 2:54 pm
by Trev
Thanks for the reply Ben, I have seen the bar in some wagons and don't like the look of it, anyone else got any idea's? Trev 8)
Posted: Mon Jan 07, 2008 7:44 pm
by Thommo
Gday Trev
Can your rear seat belts be lap belts only, or
do they have to be lap/sash?
If lap/sash, do you really need roll up, or
can you use hook up belts?
Regards, Jeff
Posted: Mon Jan 07, 2008 8:34 pm
by Trev
Hi Jeff, I definatly want the safest option, my kids will be regular passengers.
So I will be using three point belts, I just think inertia's would be allot neater if they can be installed properly, Trev 8) .
Posted: Mon Jan 07, 2008 11:37 pm
Couldnt ya mount the units above the wheel arches in the back, then run them up to a point on the C pillar ??
Sort of how they are run in a VB/H Commondore
Posted: Tue Jan 08, 2008 12:13 am
by ben
I know your problem trev as i really did not want the bar either, but inertia was the only option (i feel) for daily kid transport. The new belts i have used have to mounted within 5 degrees of the horizontal (ie top of seat), ruling out mounting lower on the arch etc. The second hands one i tried from a vl commo mount in the rear side compartment (above wheel arch where the side trim is) and would look neat and factory if you could get them to work. You still need to get the angles right for the inertia part to work properly, which i found a bit hard with the seat latch and c pillar angles.Unsure of the VB/H units, but you could also mount a couple of four point harnesses. Would be REAL safe, and stop them drawing :shock: on the back of the seats :lol:
Posted: Tue Jan 08, 2008 4:23 pm
by Trev
Blacky, exactly what I was thinking but wanted to see if someone had done it before so I could have a look at what it looks like.
Ben, straight jackets would also stop drawing on the back of the seats :lol:, Trev 8) .
Posted: Wed Jan 23, 2008 12:35 pm
by Ed
Guys,
rear belts are pretty easy to do (on an FE anyway), but should be similar.
I mounted my reels on top of the wheel arch. (like an XD falcon).
I used XD falcon wagon reels and belts.
the top mount is done by cutting out a slot in the rear of the pillar,
sliding in a 10mm plate with a 7/16" UNF thread cut in it.
stitch welding the plate in to the pillar. done, mine passed engineering like this.
in this pic you can see where the reel sits.
if you look carefully in this pic you can see wherre the plate is stitched into the pillar.
the belt runs in the narrow gap between seat and body.
Ed
Posted: Wed Jan 23, 2008 6:34 pm
by Trev
Thanks ed, thats pretty much what I ended up doing, thanks also for the pic's, Trev 8)
Posted: Wed Jan 23, 2008 8:51 pm
by Craig
Nice work ED on a side note how successfull is the Dynamat at stoping heat and sound i'm replacing floor coverings soon and was thinking about doing the firewall
Posted: Wed Jan 23, 2008 8:55 pm
by Mephious
New thread "Dynamat" !!!
Very curious about its ability also please.
Posted: Sat Jun 14, 2008 1:32 pm
by strogger
Anyone fitted Child seat anchor points in a wagon ?
if so could you please post a pic.
Thanks...
Posted: Sun Jun 15, 2008 1:09 pm
by strogger
Thanks Tim. 8)
I dont have a wagon yet, but am exploring all options..
