rosco wrote:
So, Andrew.............. you didn't get the page you wanted - and got precious little else but ramble this time..............
apologies,
I think he may have got a really good answer there Rosco!
You mentioned body widths, showing only a half inch overall difference.
Soooo if he was told they are EH offset I'm guessing they may not clear either especially when lowered. Although when he says EH spacing is this for the backspacing? If so it would explain the fouling of the gaurd with the extra inch or so over standard.
Aust(mod) quite a few years ago a mag did an article on checking offset for wheel clearance, I can't seem to find it, BUT if you take off your front wheel and then put an axle stand under it to allow the car to drop back to ride height (careful placement of the stand is needed under the wishbone so as to allow the suspension to sit at normal driving position).
Then take a either a straight edge or 600mm builders level and place it across the surface of the disc where the wheel studs are. Making sure you have it near the gaurd lip (top).
Then with either a small ruler (300mm or tape measure) measure from the gaurd lip to the edge of the builders level or straight edge that is against the disc wheel stud face.
This will tell you how much room you have.
Next Measure from the back of the centre of the rim (hopster) to the outside edge of the rim. Basically place the straight edge from lip to lip of the rim passing over the centre. Measure down to the centre of the back of the rim and this will tell you how much backsping you have.
If its a 6' rim and you have 2' of backspacing this will mean you have 4' going out the other way. Compare that with the clearance you measured to the gaurd lip and this will show how little clearance you have (of which you already know). But will give you an idea of how to get an offset to suit. Also use the same method to check how far in (known as backspacing) to the centre of the car you can go before fouling on steering arms.
If I get a chance I'll try and find the article although I don't like my chances finding it....
Hope this helps.
