arrrrrr frustration...
hey team i can get bonnet open, the guy who i bought the car off originally made some garbage leever under the bonnet, that some times works & some times doesn't... first i need to get it open then i need a new thingymebob so i dont have any problems in the future...
aren't ek's supposed to have an internal pully thing to open bonnet from inside the car...
matty martin
faaaaaaaaaaaaaaark
mattymartin
faaaaaaaaaaaaaaark
go the wagons....
smooth
Re: faaaaaaaaaaaaaaark
NO!mattymartin wrote: aren't ek's supposed to have an internal pully thing to open bonnet from inside the car...
matty martin
They have a lever under the front of the bonnet. The internal cable is a pin lock. If it is fitted you pull it out and then use the lever to open the bonnet.
Regards, Smooth
mattymartin
thanks smooth...
can i get new bonnet opening and closing thigymebobs... as there is no pin set up i just cant get leaver to open...
aaaaaaaaaaaaaah
matty martin
aaaaaaaaaaaaaah
matty martin
go the wagons....
61FBspecial
mattymartin
aaaaaaaaaaaaaarrrrrh
thanks guys
i'm gonna just give it to the mechanic like that...
he can sort it out...
go the wagons....
