WTB: grey motor lifting hook
Hi FBEKers,
im after a grey motor lifting hook
cheers
Re: WTB: grey motor lifting hook
If you want one as a collectible, no drama. If you want one to use a fair bit, you are probably better off going to Bunnings and buying a synthetic lifting sling. About 1/4 the price, and easier to use.
Slings work great. I’ve picked up the odd one left on site by the riggers.
fraze
Post by fraze »
I made one using scrap steel lying about in the workshop. I copied the one shown in the workshop manual . The drawing in the manual doesn’t show dimensions but they are obvious when you look at the engine. Best thing I have done, just so easy to use, especially when used in conjunction with an engine leveller ($40 bucks or so from Supacheap). Cheers, Fraze
engine leveller yes, i also saw the other day a modified engine crane with a boat winch mounted on it which helps with the angling of the engine too
https://www.gumtree.com.au/s-ad/footscr ... ios_social
