One for the brains trust
Jason
Post by Jason »
Hi All,
My FC runs a grey 132, with 1&1/16 inch brake slaves on the rear. My Ek & FB each run a grey 138 with 1 inch rear brake slaves. All have 1&3/16 on the front.
Wouldn't the bigger motor run bigger brake cylinders not smaller? Just one of those quirky moments where I'm ordering parts, drinking beer and thinking that there must be a logic to what I don't understand.
Jason
Jason
______________
Grey and proud!
Re: One for the brains trust
Jason,
The standard FX-FC brakes are quite prone to rear wheel lockup (that's if you can stomp down hard enough on the brake pedal to cause it). I believe the prototype testing before the release of the FX was done with the equivalent of a five-passenger load in the car, and so the suspension and brakes were set up for this condition. Hence the advice to carry a bag of cement in the boot of your humpy. With just the driver in the car and an empty tank, the cars were quite tail-happy and the brakes were proportioned too much to the rear.
GM-H never did anything in a hurry. Eleven years later, when the FBs came out, they had 1" rear wheel cylinders, making them only slightly less prone to rear-wheel lockup under hard braking. But the FBs have 1-3/4" wide brakes, so you get about two decent stops from speed before the brakes fade away, instead of not-quite one with an FC.
A disc-braked HD must have been a wonder at the time . . .
Jason
Post by Jason »
Hi Rob,
Thanks so much for that, makes perfect sense.
I always thought the cement was for the body roll but the braking theory makes more sense, my first car was a FJ holden ute. I don't know how many times old blokes would tell me to put a bag of cement in the back.
Jason
______________
Grey and proud!
