PITMAN SHAFT SEAL
fraze
PITMAN SHAFT SEAL
Post by fraze »
I need to replace the original "felt" pitman shaft seal in my FB steering box. Does anyone have info on a replacement seal? Thanks, Fraze
Re: PITMAN SHAFT SEAL
I want to do the same Fraze. Thought I’d take shaft and seal to my local and see if they can match with a new one.
fraze
Post by fraze »
OK. A modern lip seal is available. Size is 1.000 id x 1.437 od x .250 inch. Cost me $5.00! Cheers, Fraze
FbSTDwagon
Post by FbSTDwagon »
fraze wrote: Wed Oct 03, 2018 12:00 pm OK. A modern lip seal is available. Size is 1.000 id x 1.437 od x .250 inch. Cost me $5.00! Cheers, Fraze
Cheers Fraze!
You just made my day!
Drew
Dr Terry
Post by Dr Terry »
It's a 'standard' imperial size TC seal.
1.437" is 1-7/16". So the seal is 1" x 1-7/16" x 1/4".
It will work much better if you remove the pitman shaft & polish the seal area. Many are quite rusty at this age.
Dr Terry
fraze
Post by fraze »
Because of a bit of wear on the pitman shaft, I found that i got a bit of seepage past the seal using 90 oil so I cleaned that out and filled the steering box with Penrite steering box grease and all is good now, no leakage since. cheers, Fraze
SKF part number CR9837.
