Position of seat belt plates
Hi Guys
I need some info on the easiest way to put the seat belt strengthening plates into the B pillar of my Ute, can I drop both the top and bottom plates down from the top of the pillar and then plug weld or do I have to cut into the side of the pillar?
Also I would appreciate a measurement on where the top plate goes, measurement from the floor to the bolt hole?
Any help would be great don't really want to cut into the pillars if I can get away with it
ekv8ute
Re: Position of seat belt plates
Post by ekv8ute »
Hi Neil, I dropped my plates in from the top then plug welded them . I recall that it’s very difficult to get the bottom plates past the door catch attachment point.
I ended up putting the bottom plate on the wall behind the seat where you have access to the rear tray under the floorboards.
About here cobberImage
CHOPPED
Post by CHOPPED »
hi neil
if i catch up with you next weekend have a look at how i did the chopped ute
i ran retractable belts mounted under the rear parcel shelf
nice and clean and out of the way
HEY IT WASNT ME
Thanks Guys
Just sent and email to the engineer and he is happy if I put the reels were EKV8 suggests which I think is also the way to go or I'll go under the parcel shelf as you suggest Paul.
Thanks Blacky you always come through mate that photo give me a pretty good Idea of were I need to be.
