Park lights
John
Park lights
Post by John »
When I pull my lights onto park the rh rear indicator stays on and the indicator lights on the dash stay on (solid light)
When I pull the light switch all the way out the lights are fine??
Also no horn at all. New button but no go. Horn works fine direct to battery.
Any ideas ?
John
ingredient in beer
John
Re: Park lights
Post by John »
Still got me stumped. Had a fiddle last night but nothing obvious. Might need to pull the wheel off and check the wiring through the column.
Anyone got any other ideas?
ingredient in beer
Re: Park lights
Have you checked the column is earthing properly? Other than that I've got nothing.
Re: Park lights
I think Devilrod is onto it - sounds like a crook earth , does the horn work if you short from the brass ring to the steering column shaft ?
John
Re: Park lights
Post by John »
Thanks guys. I'll have a bit more of a look on the weekend.
ingredient in beer
John
Re: Park lights
Post by John »
All sorted. Thanks guys.
Bad earth for the lights and the horn issue was the new rare spares button was a bit tight in the hole in the wheel, quick file out and the horn button goes all the way in to touch the brass ring.
All working fine :)
ingredient in beer
