138 twin stromberg carb linkage
BIGREVNEV
Post by BIGREVNEV »
g,day all , i,m sorta new on this forum but not new to old holdens , i,m putting together a nice ek sedan ,. i,m doing everything at my smash / custom shop in my spare time which means late nights , i,m having an issue connecting up twin strombergs , i,ve re jetted them & installed venturi,s , but i,m having trouble connecting them to gether & to the stock linkages ,.ive got 2 methods at hand , 1 , a rod between the throttle body ,s but i can only connect to one as the other has a press fit lever with no nut attachment , 2 , i,ve connected both carb,s up with an old school system n,o,s setup with adjustable ball socket linkages which operates the carb,s in sync ok but is proving to be a mission to connect up to the standard linkage , i,m using a monaro motors inlet manifold & extractors ant thoughts cheers & beers , big rev nev
Re: 138 twin stromberg carb linkage
Can ya post a pic of what you have Nev ?
BIGREVNEV
Post by BIGREVNEV »
yeah no worries blacky cheers
